Hi all, I have a question about landsat processing. i am trying to produce a
nice 15m resolution "true color image" from landsat 7 data. I am using band 3
(red) band [2+4]/2 (green) and band 1 (blue). These three bands produce a very
nice 30m res image with d.rgb. I would like to incorporate the 15m res band 8
though. I am going about this by using i.rgb.his and i.his.rgb as described in
the book. I get an image that is 15m res, however the colors become a little
distorted, namely, the urban areas become purple (instead of grey) and the
vegetated areas become an ugly bright green. I have tried using both an
histogram optimized band 8 (r.rescale) and the original band 8.
Anybody have any experience with this? I am really interested in eventually
getting images that look like those produced by NASA here:
http://photojournal.jpl.nasa.gov/catalog/PIA03372
My next step will be to add shading using shade.rel.sh, or some modification of
r.slope.aspect. Any input would be helpful as I can't figure out how to keep
the colors looking realistic.
Many thanks.
-ian
One option which should preserve the colours would be to convert to
HSV with rgb.hsv.sh, replace or modify the intensity (V) channel, then
convert back to RGB with hsv.rgb.sh.
Note that neither of these scripts use or set the colour tables, but
d.rgb/r.composite require them be set correctly (you have to use
"r.colors color=rules" rather than "r.colors color=grey").
