[GRASSLIST:2131] v.buffer question
GRASS:/home > v.info drag.f
| Layer: drag.f Date: 7.7.2003 |
| Mapset: PERMANENT Organization: MIHA STAUT DIPLOMSK |
| DataBase: /home/miha |
| Title: ( drag.f) |
| Type of Map: Vector (level: 2) Number of Categories: 1 |
| Number of lines: 1 |
| Number of areas: 1 |
| Number of islands: 1 |
| Projection: UTM (zone 33) |
| N: 194000 S: 30000 |
| E: 623000 W: 375000 |
| Source date: |
| Original scale 1:25000 |
| Map threshold: 0.00000 |
| Comments: |
(I know v.info is from GRASS 5.3. I just wanted to show what type of vector I am dealing with.)
v.buffer in=drag out=drag.buff type=area buff=500
Areas buffers ... 100%
Building parts of topology ...
1 primitives registered
Number of nodes : 1
Number of primitives: 1
Number of points : 0
Number of lines : 0
Number of boundaries: 1
Number of centroids : 0
Number of areas : -
Number of isles : -
Snapping boundaries ...
All vertices: 6115
Registered points (unique coordinates): 1725
Nodes marked as anchor : 1723
Nodes marked to be snapped : 2
Snapped vertices : 1465
New vertices : 17
Breaking boundaries ...
Intersections: 0
The command ran for 2 hours and did not manage to buffer the vector. What have I done wrong? Why did the v.buffer show no area if I converted an area vector to GRASS 5.7?
Thanks, Miha Staut
_________________________________________________________________
Add photos to your messages with MSN 8. Get 2 months FREE*. http://join.msn.com/?page=features/featuredemail
New vertices : 17
Intersections: 0
Does it crash or does it finish successfully with empty output?
Is it "Intersections: 0" the last output?
Can you send me 'drag' in 5.7 format?
Radim
