[GRASSLIST:2133] 5.7 and postgres on Mac OSX
I'm trying again to build grass 5.7 (from 2004_01_03 snapshots) on mac 10.2.8: make bails out when trying to create libgrass_vect.dylib because it can't locate -lpq. I've got the postgres libs and includes in my configure arguments and I can't work out where I'm going wrong. I've put the steps below - can anyone suggest what's going on?
David
CFLAGS="-g -Wall" ./configure --with-grass50=//usr/local/src/grass53_exp_2004_01_03 --with-postgres-includes=/usr/local/pgsql/include/ --with-postgres-libs=/usr/local/pgsql/lib/ --with-opengl=no
make mix
make
[clipped]
gcc -L/usr/local/src/grass57_exp_2004_01_03/dist.powerpc-apple-darwin6.8/lib -dynamiclib -Wl,-flat_namespace,-U,_cuserid -undefined suppress -L/usr/local/src/grass57_exp_2004_01_03/dist.powerpc-apple-darwin6.8/lib \
         OBJ.powerpc-apple-darwin6.8/area.o OBJ.powerpc-apple-darwin6.8/array.o OBJ.powerpc-apple-darwin6.8/box.o OBJ.powerpc-apple-darwin6.8/break_lines.o OBJ.powerpc-apple-darwin6.8/break_polygons.o OBJ.powerpc-apple-darwin6.8/bridges.o OBJ.powerpc-apple-darwin6.8/buffer.o OBJ.powerpc-apple-darwin6.8/build.o OBJ.powerpc-apple-darwin6.8/build_nat.o OBJ.powerpc-apple-darwin6.8/build_ogr.o OBJ.powerpc-apple-darwin6.8/build_post.o OBJ.powerpc-apple-darwin6.8/build_shp.o OBJ.powerpc-apple-darwin6.8/cats.o OBJ.powerpc-apple-darwin6.8/close.o OBJ.powerpc-apple-darwin6.8/close_nat.o OBJ.powerpc-apple-darwin6.8/close_ogr.o OBJ.powerpc-apple-darwin6.8/close_post.o OBJ.powerpc-apple-darwin6.8/close_shp.o OBJ.powerpc-apple-darwin6.8/constraint.o OBJ.powerpc-apple-darwin6.8/dangles.o OBJ.powerpc-apple-darwin6.8/error.o OBJ.powerpc-apple-darwin6.8/field.o OBJ.powerpc-apple-darwin6.8/find.o OBJ.powerpc-apple-darwin6.8/graph.o OBJ.powerpc-apple-darwin6.8/header.o OBJ.powerpc-apple-darwin6.8/hist.o OBJ.powerpc-apple-darwin6.8/init_head.o OBJ.powerpc-apple-darwin6.8/intersect.o OBJ.powerpc-apple-darwin6.8/legal_vname.o OBJ.powerpc-apple-darwin6.8/level.o OBJ.powerpc-apple-darwin6.8/level_two.o OBJ.powerpc-apple-darwin6.8/line.o OBJ.powerpc-apple-darwin6.8/list.o OBJ.powerpc-apple-darwin6.8/map.o OBJ.powerpc-apple-darwin6.8/net.o OBJ.powerpc-apple-darwin6.8/open.o OBJ.powerpc-apple-darwin6.8/open_nat.o OBJ.powerpc-apple-darwin6.8/open_ogr.o OBJ.powerpc-apple-darwin6.8/open_post.o OBJ.powerpc-apple-darwin6.8/open_shp.o OBJ.powerpc-apple-darwin6.8/overlap.o OBJ.powerpc-apple-darwin6.8/overlay.o OBJ.powerpc-apple-darwin6.8/poly.o OBJ.powerpc-apple-darwin6.8/read.o OBJ.powerpc-apple-darwin6.8/read_nat.o OBJ.powerpc-apple-darwin6.8/read_ogr.o OBJ.powerpc-apple-darwin6.8/read_post.o OBJ.powerpc-apple-darwin6.8/read_shp.o OBJ.powerpc-apple-darwin6.8/remove_duplicates.o OBJ.powerpc-apple-darwin6.8/rewind.o OBJ.powerpc-apple-darwin6.8/rewind_nat.o OBJ.powerpc-apple-darwin6.8/rewind_ogr.o OBJ.powerpc-apple-darwin6.8/rewind_post.o OBJ.powerpc-apple-darwin6.8/rewind_shp.o OBJ.powerpc-apple-darwin6.8/select.o OBJ.powerpc-apple-darwin6.8/sindex.o OBJ.powerpc-apple-darwin6.8/snap.o OBJ.powerpc-apple-darwin6.8/tin.o OBJ.powerpc-apple-darwin6.8/type.o OBJ.powerpc-apple-darwin6.8/window.o OBJ.powerpc-apple-darwin6.8/write.o OBJ.powerpc-apple-darwin6.8/write_nat.o OBJ.powerpc-apple-darwin6.8/write_post.o -lgrass_gis -lgrass_datetime -lintl -lgrass_dig2 -lgrass_shape -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase -lpq -o /usr/local/src/grass57_exp_2004_01_03/dist.powerpc-apple-darwin6.8/lib/libgrass_vect.dylib
/usr/bin/libtool: can't locate file for: -lpq
/usr/bin/libtool: file: -lpq is not an object file (not allowed in a library)
make[3]: *** [/usr/local/src/grass57_exp_2004_01_03/dist.powerpc-apple-darwin6.8/lib/libgrass_vect.dylib] Error 1
make[2]: *** [subdirs] Error 1
make[1]: *** [subdirs] Error 1
make: *** [default] Error 1
The build system is ignoring your --with-postgres-libs= setting in
this instance (no -L/usr/local/pgsql/lib switch).
I'm not particularly familiar with the 5.7 build system, but
lib/vector/Vlib/Makefile should probably have:
  EXTRA_LIBDIRS = $(PQLIBPATH)
Either that, or EXTRA_LIBS should have:
  EXTRA_LIBS = ... $(PQLIBPATH) $(PQLIB)
rather than just $(PQLIB).
