[GRASSLIST:2136] 5.7 and postgres on Mac OSX
I'd noticed the missing -L/usr/local/pgsql/lib but didn't know how to deal with it. I've tried both the makefile edits that Glynn suggested and either solves the problem for creating libgrass_vect.dylib. The same problem then happens for libgrass_sites.dylib. The sites Makefile contains:
EXTRA_LIBS=$(GISLIB) $(DBMILIB) $(VECTLIB)
If I add $(PQLIBPATH) $(PQLIB) then that creates but then libgrass_interpfl.dylib fails...
My pgsql libraries are in /usr/local/pgsql/lib, which seems to be the default for PostgreSQL - do I need to chase through the makefiles or am I missing something simpler - I've tried linking libpq2.2.so into /usr/local/lib and that doesn't help.
Any suggestions?
David
On Monday, January 5, 2004, at 10:41 pm, Glynn Clements wrote:
David Orme wrote:
I'm trying again to build grass 5.7 (from 2004_01_03 snapshots) on mac
10.2.8: make bails out when trying to create libgrass_vect.dylib
because it can't locate -lpq. I've got the postgres libs and includes
in my configure arguments and I can't work out where I'm going wrong.
I've put the steps below - can anyone suggest what's going on?
The build system is ignoring your --with-postgres-libs= setting in
this instance (no -L/usr/local/pgsql/lib switch).
I'm not particularly familiar with the 5.7 build system, but
lib/vector/Vlib/Makefile should probably have:
  EXTRA_LIBDIRS = $(PQLIBPATH)
Either that, or EXTRA_LIBS should have:
  EXTRA_LIBS = ... $(PQLIBPATH) $(PQLIB)
rather than just $(PQLIB).
On Tuesday 06 January 2004 11:54, David Orme wrote:
contains:
Any suggestions?
If compiled with postgres, PQLIB is required in all vector modules,
so correct would be probably
VECT_LDFLAGS = $(PQLIBPATH) in Grass.make.in
and
EXTRA_LDFLAGS = $(VECT_LDFLAGS) in all vector Makefiles
but for now, I have added $(PQLIBPATH) to LDFLAGS in Grass.make.in
Radim
David
Thanks Radim, that did the trick - though the first time I edited the Makefile after configure rather than before and wondered why it wouldn't work.
I've now run into a problem with compiling r.in.gdal:
gcc -L/usr/local/src/grass57_exp_2004_01_03/dist.powerpc-apple-darwin6.8/lib -L/usr/local/pgsql/lib/ -o /usr/local/src/grass57_exp_2004_01_03/dist.powerpc-apple-darwin6.8/etc/bin/cmd/r.in.gdal OBJ.powerpc-apple-darwin6.8/gbgetsymbol.o OBJ.powerpc-apple-darwin6.8/gdalbridge.o OBJ.powerpc-apple-darwin6.8/main.o -lgrass_gproj -lproj -L/usr/local/lib -lgdal.1.1 -lgrass_gis -lgrass_datetime -lintl -lgrass_I -lgrass_vask -lncurses -L/usr/local/lib -lgdal.1.1 -ldl > -lz
ld: warning can't open dynamic library: libtiff.dylib (checking for undefined symbols may be affected) (No such file or directory, errno = 2)
ld: warning can't open dynamic library: libpng.3.dylib (checking for undefined symbols may be affected) (No such file or directory, errno = 2)
I've configured grass with --with-gdal and the configure script finds gdal-config in /usr/local/bin. I suspect this is a gdal build issue but I'm not sure. The r.in.gdal build links to libgdal.1.1.dylib, which in turn should link libtiff and libpng. These _are_ in /usr/local/lib, so I don't get why they aren't found.
rwxr-xr-x 1 dorme staff 220932 Sep 29 2002 /usr/local/lib/libpng.3.1.2.1.dylib
lrwxr-xr-x 1 root wheel 20 Jan 6 10:31 /usr/local/lib/libpng.3.dylib -> libpng.3.1.2.1.dylib
-r-xr-xr-x 1 root wheel 664668 Nov 18 15:04 /usr/local/lib/libtiff.3.6.0.dylib
lrwxr-xr-x 1 root wheel 19 Jan 6 10:31 /usr/local/lib/libtiff.dylib -> libtiff.3.6.0.dylib
The shared libraries listings for libgdal is as follows - should the libtiff and libpng have a relative or absolute path?:
bash-2.05a$ otool -L /usr/local/lib/libgdal.1.1.dylib
/usr/local/lib/libgdal.1.1.dylib:
        ./libgdal.1.1.dylib (compatibility version 0.0.0, current version 0.0.0)
        libtiff.dylib (compatibility version 0.0.0, current version 0.0.0)
        libpng.3.dylib (compatibility version 0.0.0, current version 0.0.0)
        /usr/lib/libz.1.1.3.dylib (compatibility version 1.0.0, current version 1.1.3)
        /usr/local/lib/libdl.1.dylib (compatibility version 1.0.0, current version 1.0.0)
        /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 63.0.0)
Any hints gratefully received.
David
contains:
Any suggestions?
and
Radim
David
