[GRASSLIST:2150] stream networks
I am trying to use GRASS 5.7 for some hydrologic modeling; in particular, I need to develop a stream layer composed of segments that know what their downstream neighbour is. I know there are functions like r.watershed that will produce a stream layer, but not a "network" as I describe, and there are network functions that I generally see used for roads, but not streams. Could these be combined in some way to produce what I need, or am I barking up the wrong tree? Any advice would be most helpful.
Chris
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
I don't the output from r.watershed, if lines are oriented down
and connected at nodes, you can place new points at nodes (v.net operation=nodes),
assign categories to points and print start and end point category for each
point (v.net operation=report). Then, with some scripting, extract
the downstream neighbour for each line, i.e find which line has as starting point
the point which is end point of the line.
Radim
