Hi, folks.
I've been away from the list and GRASS in general for a little while.
Last time I used GRASS, I was having problems with r.in.gdal
segfaulting when I tried to import DEMs.
I have a renewed interest in GIS and wanted to play around with GRASS
some more. I downloaded the binary version of Grass (5.0.2) and
installed it on Knoppix (a Debian-based Live-CD). GRASS ran okay, but
I had the same old segfault problem. I searched the mailing list and
found that the solution which has worked for others is to compile
grass from source with --with-gdal. I downloaded the source (5.0.3)
and compiled it on my Redhat 8.0 box--I already had gdal-1.1.9
installed. It compiled without errors, but I still had the segfault
problem. Here are some things I've tried, all ending with the same
result:
* Remove gdal from my system and install the binary version of GRASS.
* Uninstall the binary version, compile gdal-1.1.8 and compile GRASS
5.0.3 with --with-gdal.
* Uninstall (gdal and GRASS), install gdal-1.1.9 and compile GRASS
* At some point, I tried using GRASS 5.0.2, but that didn't work
either.
* Install the binary version of GRASS 5.0.2 and replace (symlink) the
GRASS version of libgdal.1.1.so with the one installed with gdal.
Note that the gdal utility programs seem to work fine. It's just
r.in.gdal that crashes and burns.
Here is an example of a DEM and a DRG each of which crash r.in.gdal:
ftp://gisweb1.radford.edu/dem/DEMs/36080/36080G5.zip
ftp://gisweb1.radford.edu/drgs/o36080g5.zip
And I've attached the output from running strace on r.in.gdal when it
segfaults. What are all the windoze-style paths in there for? (I
gzipped the output so it wasn't so large.)
This problem has rendered GRASS relatively useless to me because all
my data is in formats which need r.in.gdal to import them! And
the frustrating thing is that it used to all work. Many moons ago, I
compiled 5.0.2 and gdal-1.1.8 from source and r.in.gdal worked. Then
it suddenly stopped for some reason and I haven't been able to get it
to work since. (I don't think upgraded anything between the time it
worked and stopped working...but I could be wrong.)
I'd really 'preciate any help anyone could give. I've tried
everything I could think of and find on the lists.
Ben
Ben Logan
Google Answers Researcher
answers.google.com
When you're searching for information, Google Answers.
OpenPGP Key ID: A1ADD1F0
Fingerprint: E32C 1CF9 C2FE DFC9 BB5C A24F 57DB 5679 A1AD D1F0
Get it from http://cyclist.wblogan.net/benlogan.gpg
(attachments)
output.gz (5.15 KB)
