[GRASSLIST:2172] building 5.7 on cygwin
Building 5.7 on cygwin I encounter an error - I can not get datetime to build. It fails with: undefined reference to `_WinMain@16' (complete output below). Any suggestions greatly appreciated.
Rich
gcc -s -L/usr/local/lib -L/lib/mingw -I/usr/include/mingw -I/usr/include/w32api
-L/home/Rich/grass57_exp_2004_01_03/dist.i686-pc-cygwin/lib \
         OBJ.i686-pc-cygwin/between.o OBJ.i686-pc-cygwin/copy.o OBJ.i686-pc-cygwin/same.o OBJ.i686-pc-cygwin/diff.o OBJ.i686-pc-cygwin/error.o OBJ.i686-pc-cygwin
/format.o OBJ.i686-pc-cygwin/incr1.o OBJ.i686-pc-cygwin/incr2.o OBJ.i686-pc-cygwin/incr3.o OBJ.i686-pc-cygwin/local.o OBJ.i686-pc-cygwin/misc.o OBJ.i686-pc-cygw
in/change.o OBJ.i686-pc-cygwin/scan.o OBJ.i686-pc-cygwin/sign.o OBJ.i686-pc-cygwin/type.o OBJ.i686-pc-cygwin/tz1.o OBJ.i686-pc-cygwin/tz2.o OBJ.i686-pc-cygwin/v
alues.o -o /home/Rich/grass57_exp_2004_01_03/dist.i686-pc-cygwin/lib/libgrass_d
atetime.
/usr/lib/gcc-lib/i686-pc-cygwin/3.3.1/../../../libcygwin.a(libcmain.o)(.text+0x7
c): undefined reference to `_WinMain@16'
collect2: ld returned 1 exit status
make[2]: *** [/home/Rich/grass57_exp_2004_01_03/dist.i686-pc-cygwin/lib/libgrass
_datetime.] Error 1
make[2]: Leaving directory `/home/Rich/grass57_exp_2004_01_03/lib/datetime'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/home/Rich/grass57_exp_2004_01_03/lib'
make: *** [default] Error 1
Richard Greenwood
www.greenwoodmap.com
Shared libraries aren't yet supported for 5.7 on Cygwin; you need to use
the --enable-shared=no option to the configure script to build static
libraries.
Rich
alues.o -o
atetime.
make[2]: ***
_datetime.] Error 1
Richard Greenwood
alues.o -o
/home/Rich/grass57_exp_2004_01_03/dist.i686-pc-cygwin/lib/libgrass_datetime.
It appears that you are trying to build shared libraries, which aren't
supported on Cygwin (building Windows DLLs is significantly more
complex than building Unix shared libraries).
You need to use the --disable-shared configure switch.
Paul,
Thank you very much, that was it. I would be embarrassed to admit how much time I wasted on this. Were there any obvious clues that I missed?
Rich
libraries.
Rich
Richard Greenwood
