I would like to make a cell and a site grid with
Grass but I have some problems.
I use the command v.mkgrid to mave a vector grid
and it works
v.mkgrid map=prova grid=10,10,
coordinate=1630000,4800000 box=1000,1000 angle=0
type=rows (text or tclk)
then I run v.support and I select
1 - Build topology information (Needed for
digit)
The output say:
Selected information from vector header
Organization: GRASS Development Team
Map Name:
Source Date:
Orig. Scale: 0
Snapping threshold 0.00
Snapp No snapping will be done
Reading Vector file 100%
Building areas 100%
Unclosed area, free end or edge inside area:
line 30
line 60
line 90
line 120
line 180
line 210
line 421
Building islands (no islands present)
Attaching labels
PNT_TO_AREA failed: (1630500.000000,
4800500.000000) (Category 91)
PNT_TO_AREA failed: (1631500.000000,
4800500.000000) (Category 92)
PNT_TO_AREA failed: (1632500.000000,
4800500.000000) (Category 93)
4808500.000000) (Category 13)
PNT_TO_AREA failed: (1633500.000000,
4808500.000000) (Category 14)
Selected file is [prova]
So I cannot convert the vector grid in site and
raster format.
Someone can help me?
Thank you a lot.
Leonardo Lami
