As the man page for ps.select says, there should be a file
in $GISBASE/etc/paint/ps.devices with the name you are
selecting (large printer?). Check this file (it is ascii)
and look at the settings. You should see something like:
level: 2
page width: 8.5000
page height: 14.0000
Are these setting what you expect?
If not, you can create your own custom page size.
John
-----Original Message-----
From: J. Brian Adams [mailto:brian.adams@fandm.edu]
Sent: Wednesday, January 14, 2004 2:29 PM
To: grass list
Subject: [GRASSLIST:2221] Changing Paper Size in ps.map
I have been trying to create a large scale map (18" x 24") using
ps.map. I set ps.select to the large printer, but when I run ps.map
and view the postscript file it only shows a quarter of the image. I
convert the file using ps2pdf then view it in Acrobat Reader. Acrobat
seems to be stuck on standard US Letter. However, I get the same
result if I view the ps file directly in Mac's Preview.
I am running grass 5.0.2 on Mac OS X 10.3.
Brian
I had created a new file for the printer by copying one of the others and then making the changes. It is
level: 2
page width: 18.0
page height: 24.0
top margin: 0.5
bottom margin: 0.5
left margin: 0.25
right margin: 0.25
resolution: 300
level: 2
page width: 8.5000
John
To: grass list
Brian
> level: 2
> page width: 8.5000
level: 2
page width: 18.0
page height: 24.0
top margin: 0.5
bottom margin: 0.5
left margin: 0.25
right margin: 0.25
resolution: 300
Those files (and ps.select) tell ps.map what size the page is supposed
to be, so that it can position and scale the output appropriately.
Nothing in the resulting PostScript file will force the printer/viewer
to use the chosen page size.
