[GRASSLIST:2233] Re: trend surface analysis - New Problem
Hello.
I did as Roger said, and used
base2 <- surf.ls(2, east(G), north (G), isobase)
isobase$isobases.auto not isobase, which is a list that may contain more
than one raster layer.
Roger
but then I get this error msg:
Error in as.double.default(z) : (list) object cannot be coerced to
double
How can fix it?
I tried as.double(), but get the same msg.
Thanks again
Carlos
        Carlos Henrique Grohmann - Guano
    Geologist - MSc Student at IGc-USP - Brazil
       Linux User #89721 ICQ: 214752832
Citando Roger Bivand <Roger.Bivand@nhh.no>:
> Hello all
> I'm trying to do some trend surface analysis with GRASS data in R,
but I with some problems:
> 1 - when I get the raster from GRASS, surf.ls() doesn't accept it,
since its not in x,y,z format:
>> str(isobase)
> List of 1
> $ isobases.auto: num [1:241266] 771 770 769 768 767 ...
> So, how can I change this to a format that surf.ls() understands?
isobase$isobases.auto is the z argument. You can generate the x by
east() of the object returned by gmeta(), and y by north() of this
object. I'm not sure how well surf.ls() scales to this number of
points, though.
> 2 - I'll try several degrees of surfaces, so I'll use surf.ls(),
but
what about residuals? can I get them with residuals()?
Yes, residuals() should work. Again, scaling to this number of points
is an issue. On the other hand, the residuals and fitted values will
drop straight into the GRASS location.
Roger
> thanks in advance
> Carlos Grohmann
Roger Bivand
NHH, Breiviksveien 40, N-5045 Bergen, Norway
Roger Bivand
