[GRASSLIST:2250] Help base gis task for beginner
I've read offical Grass Tutorial but it's difficult for beginner to understand which commands need I use to decide my task.
I've imported png image into grass location. What commands need I use to do following:
1. Draw contours of some territories
2. Describe this territories in SQL database table(s)
3. Draw contour(s) by SQL query.
4. Display selected contours with fixed scale (1:1000 for example) or with fixed map size and autoscaling.
5. Export map or part of map with selected contours into rast image.
Can anyone describe how can I do this step by step with full commands and params?
Eugene Prokopiev
