Can I draw vector map over rastr map in one monitor such as
GRASS:~/grass-data > d.mon start=x0 select=x0
GRASS:~/grass-data > d.rast topo
GRASS:~/grass-data > d.rast -o water
Or how can I combine rast image with vector contours on it?
Eugene Prokopiev
Most drawing commands (including d.vect and d.vect.area) overlay
whatever is already on the monitor.
v.to.rast will convert a vector layer to a raster layer at the current
region's resolution. The resulting raster layer can be overlaid upon
other raster layers using r.patch.
