I have a question on Database management with GRASS 5.7...
In the part of the tutorial "Geometry Stored in PostGRASS database table using PostGIS" (http://grass.itc.it/grass51/tutorial/geom_storage.html#PostGRASS)
The example says to take a shape file registered with v.shape.register and use
v.convert to import it into a PostGRES database with PostGIS format.
It did not work with me (gives me a "vector map not found" error), and the man page for v.convert says that it is used to convert 5.0 vectors to 5.1...
Am I doing something wrong or am I missing something?
Francesco Pirotti
CIRGEO -University of Padua
phone. 049 - 8272522
fax. 049-8272686
cel. 328-2126861
francesco.pirotti@unipd.it
On Monday 19 January 2004 08:57, francesco.pirotti wrote:
using PostGIS"
use v.convert to import it into a PostGRES database with PostGIS format. It
page for v.convert says that it is used to convert 5.0 vectors to 5.1... Am
v.convert converts 5.0 vectors to 5.7 format. If you want to store vectors in
PostGIS, run v.in.ogr.
Radim
> Hi all,
> using PostGIS"
I have fixed the tutorial. Thanks for notification.
