[GRASSLIST:2332] i.his.rgb
Hi all, I have a problem that I can't quite figure out with i.his.rgb. I have
been manipulating landsat 7 data using the method described in the GRASS book.
I am trying to add in band 8. So far I can get this to work, in a number of
different ways. The way I have found to be the most successful (for retaining
the colors that I want) is to enhance the contrast of all 4 bands using
r.rescale, converting to his (i.rgb.his), and converting back to rgb (i.his.rgb
with band 8 as intensity). The problem is that a lot of "holes" appear in the
final rgb files. Single pixels seem to be converted to a value of zero, even
though the same pixels (in space) are not zeros or nulls in the original files
(pre i.rgb.his > i.his.rgb). I have posted a specific example here.
www.uweb.ucsb.edu/~ian_macmillan/hisrgb.jpg
Band1x is the i.his.rgb converted blue file, while bands 1,2,3,8 are the
original rescaled files. The black dots are clearly visible scattered
throughout the image. They each have a value of zero.
Anybody have any ideas what is going on?
thanks, Ian
final rgb files.
I don't think that the usage of r.rescale is a good idea. Like that
you are manipulating the pixels instead of the color table.
Why not applying the HIS/RGB procedure and then using r.colors on
the resulting 3 channels?
Yes - probably due to r.rescale usage.
It's not the procedure proposed in the book (there r.colors is recommended).
IMHO pixel values should not be touched.
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
