[GRASSLIST:2342] NVIZ doesn't run
hello
I am using grass5.0.2 on slackware 9.1.
Although I installed graphic card driver for OpenGL
I received this message in using NVIZ:
/http://www2.gis.uiuc.edu:2280/modviz/
Loading Data
Update elev null mask
Loading Data
translating colors from fp
Adding panels from /usr/local/grass5/etc/nviz2.2/scripts
Nv_(panels)
toplevel made
child killed: segmentation violation
    while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script el=elv1 -name NVIZ >&@stdout"
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
    invoked from within
"if {$argv == ""} {
#no arguments
eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
    (file "/usr/local/grass5/bin/nviz" line 16)
I will appreciate if anyone tells me the solution
kind regards
A.Temiz - TURKEY
______________________________________
Inflex - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
perhaps you must go into your XF86config file and enable the module for opengl by uncommenting the
Load "glx"
temiz wrote:
hello
Loading Data
Loading Data
Nv_(panels)
toplevel made
   while executing
   invoked from within
   invoked from within
"if {$argv == ""} {
#no arguments
kind regards
A.Temiz - TURKEY
