[GRASSLIST:2346] RE: vector map over rastr map in one monitor
    You can try out the following:
1. d.mon start=x0 select=x0
2. d.rast map=topo
3. d.vect map=water
It will display a raster image (topo) and overlay the vector layer (water) over it.
Good Luck.
uttam.
To: grasslist@baylor.edu
Subject: [GRASSLIST:2264] vector map over rastr map in one monitor
Date: Sun, 18 Jan 2004 15:57:35 +0300
Can I draw vector map over rastr map in one monitor such as
GRASS:~/grass-data > d.mon start=x0 select=x0
GRASS:~/grass-data > d.rast topo
GRASS:~/grass-data > d.rast -o water
Or how can I combine rast image with vector contours on it?
Eugene Prokopiev
_________________________________________________________________
NRI’s, Free Money transfer to India. http://server1.msn.co.in/msnleads/citibankrca/citibankrca2.asp?type=hottag Click here.
