On Thu, 15 May 2003 Robert.Siudak@imgw.pl wrote:
Hello!
I am quitre new user of GRASS and my question may look prosaic.
Is it possible using GRASS to cut out demanded shape of raster difined
by polygon geometry? I am looking for tool like v.cutter but for raster
layer. For example I have a DEM or scaned maps and I would like to cut
out area coresponding to my province from that.
Using the spearfish example dataset, I did:
g.list vect
to choose a suitable vector map
v.info quads
d.mon start=x0
d.vect quads
d.what.vect
and verified that there are just two areas (and some missing data)
v.to.rast input=quads output=quads12
r.support -r map=quads12
r.info quads12
still two categories, then
r.mask
which has to be run interactively, to set the region(s) you want to see to
1, the others to 0. This creates a raster called MASK, which will restrict
raster display to the cells valued 1 in the MASK
d.rast geology
Of course, this depends on the input vector areas being well-defined, and
having appropriate category values.
Hope this helps!
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
