[GRASSLIST:2410] grass53 compilation
Hi, trying to compile grass53 i get the following errors:
   GRASS GIS source code compiled.
   Compilation error in module: src/raster/r.in.gdal (ignored)
   Compilation error in module: src.contrib/GMSL/g3d (ignored)
   Compilation error in module: src.contrib/DUKE/r.terraflow (ignored)
is it due to the compiler version as the problem in grass57?
is it possible fom me to fix this changing few parameters in the sources?
thanks, Michele.
It's hard to say without seeing the actual error messages from "make".
