[GRASSLIST:2435] Bug?? v.shape.register and qgis question
Hi everyone,
Got a point on dealing with shape files:
When v.shape.register is used, it registers a shape file with its full name
(eg. myfile.shp) but when I try to paint it on the monitor (using d.m) it
gives me the following error:
Illegal vector map name .... Character <.> no allowed.
Map name not SQL compiant
Of course it does not like the dot (.) part in the "myfile.shp" but looks like
it is not possible to register a shape without its full name (dot (.)
included). Is there a way to get around this?
I am using the CVS version of 5.7....
______________
This one's for Radim, on qgis:
Are GRASS files read by Qgis? I compiled Qgis with all the libgrass and
libgrass++ but the program seems to read shapes and postGIS files. Is GRASS
somewhere?
Thanx for the time,
Francesco
This mail sent through IMP: webmail.unipd.it
On Monday 02 February 2004 12:24, francesco.pirotti@unipd.it wrote:
Hi everyone,
like it is not possible to register a shape without its full name (dot (.)
You can:
1) simply rename the directory vector/myfile.shp to vector/myfile_shp
2) register the shapefile in v.format (GUI)
3) create vector/myfile_shp/head and vector/myfile_shp/ in text editor and run v.build
______________
GRASS somewhere?
I created QGIS version which supports GRASS (using QGIS 0.9) available here:
http://mpa.itc.it/radim/qgis/qgis-0.0.9-grass0.4.tar.gz
GRASS support was not integrated to official distribution of QGIS, because
QGIS developers decided to introduce a new interface for extensions like GRASS
(data provider). This interface is now ready, and I want to update my version
to use that but I am also considering to add GRASS vectors to OGR.
BTW, recently, we have successfully compiled QGIS with GRASS support on iPAQ:
http://mpa.itc.it/radim/qgis/ipaq1.png
http://mpa.itc.it/radim/qgis/ipaq2.png
Radim
On Mon, Feb 02, 2004 at 12:24:03PM +0100, francesco.pirotti@unipd.it wrote:
Hi everyone,
This was fixed a few days ago in CVS (v.shape.register, v.shape.unregister).
I suggest to update the scripts in your local installation.
