Hi
in the programmers manual progmangrass50 (Chapter 12.19) i found an example for a socket server. I tested it and it works fine.
Unfortunately (at least for my needs) the routines desc. in 12.19 (G_sock_* which references unix_socks.c in grass5sources/grass-5.0.3/src/libes/gis) uses unix domain sockets, which generates in the /tmp/-directory a socket, which is not accessible from a processes on other machines.
so the unix sockets communication is only usable from processes on the same machine (or am I wrong here?).
so my question is: are there other routines in grass which uses internet domain sockets (which uses a host and port definition and therefore should be usable on for processes on different machines)
Thanks dani isenegger
You are correct.
The functions in unix_socks.c are there solely for communication
between the display drivers and the raster library, which only uses
AF_UNIX sockets.
No.
