I have a large number of raster files to remove from a mapset. Are wildcards available to expedite this process?
Kirk
Kirk R. Wythers tel: 612.625.2261
Dept. of Forest Resources fax: 612.625.5212
University of Minnesota email: kwythers@umn.edu
[Thursday 05 February 2004 10:53] From Kirk R. Wythers
It's far far better to use the "g.remove" function, than deleting the files by
hand (too many directories to search).
Why wouldn't you just write a small script to create the list of all your
rasters, and then call "g.remove" ?
Like
for map in ${maplist}; do g.remove ra=${map}; done
Your maplist can be created with as many wildcards as you want.
Soil & Water Laboratory
Dept. of Biological & Environmental Engineering
Cornell University
ITHACA, NY 14853
Tel: (607)255.2463
Like
Also, see g.mremove - IIRC it is just such a script...
Like
Cornell University
ITHACA, NY 14853
Tel: (607)255.2463
Scott W. Mitchell Scott_Mitchell@carleton.ca
Department of Geography and Environmental Studies
Carleton University, B349 Loeb Building (Office A209)
1125 Colonel By Drive, Ottawa, ON Canada K1S 5B6
+1-613-520-2600 ext 2695 Fax: 1-613-520-4301
That's what I'm look'n for. Unfortunately it does not seem to be implemented in 5.7 yet (sorry, I didn't say I was using 5.7 with a mid December build date).
oops... looks like I need to cvs up and try rebuilding.
On Feb 5, 2004, at 11:42 AM, Kirk R. Wythers wrote:
On Feb 5, 2004, at 10:53 AM, Paul Kelly wrote:
What about
g.mremove rast='pattern*'
>What about
I have uploaded the new parser support from Francesco Pirotti
to 5.3 and added the script to 5.7 as well.
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
