[GRASSLIST:2497] Interpolate from database
Hi list,
I have a bunch of meteorological stations (157) on a
postgres table and their respective DAILY data
(precip, temp, wind) on another table. The thing is, I
need to create daily surface maps, interpolating those
points in the database. Is there a way to do this in
GRASS, that is, input the points from the SQL table,
interpolate the data for one day and get a surface,
change the day and interpolate again, and again, for
about 1 year worth of data? Do I need grass 5.7? 5.3?
Any help would be greatlly appreciated
Thanks
Daniel
__________________________________
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online.
http://taxes.yahoo.com/filing.html
Yea, sure. Works really well once you have a script written.
Time to learn some bash scripting though!
You can use 5.0, but I suggest using 5.3+, so that you can compile
r.series which lets you do stats on the year's worth of resultant maps
(after increasing r.series' MAXFILES to something bigger than 365!).
general idea is to extract a single day's data to a sites file, do the
interpolation, & repeat.
If you have Markus & Helena's hardbound GRASS book, there's an example
there regarding r.sun I think.
general idea:
#!/bin/bash
i=1
while [ $i -le 365 ] ; do
    # generate map names convenient for xganim or r.out.mpeg
    DAY=`echo $i | awk '{printf "%03i", $1}'`
    echo
    echo "Computing radiation for day $DAY..."
    sql_extraction_command day=$i sites_out=rain.$DAY
# maybe dump to temp. file & feed that into s.in.ascii ?
    s.surf.idw sites_in=rain.$DAY rast_out=insitu_data.$DAY
    i=`expr $i + 1`
done
r.series input="`g.mlist pattern='insitu_data.*' sep=,`" \
    output=insitu_data.stddev method=stddev
good luck,
Hamish
That should say "after increasing libgis' MAXFILES". Specifically, the
macro in question is defined in src/libes/gis/G.h.
general idea:
#!/bin/bash
i=1
    echo
    i=`expr $i + 1`
done
It should be possible to do this without sql_extraction_command with
standard modules only:
v.in.db driver=pg database=my table=ms x=x y=y output=ms
i=1
     v.extract input=ms output=ms_tmp where="day=$i"
     s.surf.idw input=ms_tmp output=rain_$DAY field=xxx # or v.surf.rst
     i=`expr $i + 1`
done
Radim
