[GRASSLIST:2499] r.stats/r.report problem -- ?
I don't know if this is a problem w/ r.stats or with me (likely the latter), but when I do either r.stats or r.report on a fp map I generated, asking for 10 bins, I get the following:
  r.stats -a input=gh1.step3 nsteps=10
r.stats: 100%
0-0.099721 265214927.507447
0.099721-0.199442 100882669.359852
0.199442-0.299163 58216243.533102
0.299163-0.398884 42019678.621828
0.398884-0.498605 33211683.308533
0.498605-0.598326 27753460.722638
0.598326-0.698047 24208494.471648
0.698047-0.797768 23274803.791991
0.797768-0.897489 16712883.263959
0.897489-0.99721 899.509325
* 753529755.895994
This shows that there are only 900 m^2 of the region for the last range of values (0.89-0.99). But this is wrong. If I do the following:
d.rast gh1.step3 vallist=0.9-1
I get the attached map. There is clearly a considerable area in the range 0.89-0.99. And if I do r.stats without bins, I get:
0.897645-0.901565 2400790.389209
0.901565-0.905485 2385498.730679
0.905485-0.909404 2376503.637426
0.909404-0.913324 2402589.407860
0.913324-0.917244 2352216.885643
0.917244-0.921164 2381900.693378
0.921164-0.925084 2370207.072149
0.925084-0.929004 2558204.521136
0.929004-0.932923 2479047.700510
0.932923-0.936843 2560903.049112
0.936843-0.940763 2506932.489594
0.940763-0.944683 2676939.752074
0.944683-0.948603 2599581.950099
0.948603-0.952523 2647255.944340
0.952523-0.956443 2710221.597110
0.956443-0.960362 2701226.503857
0.960362-0.964282 2924304.816530
0.964282-0.968202 2900018.064747
0.968202-0.972122 2994466.543903
0.972122-0.976042 3116799.812143
0.976042-0.979962 3146483.619878
0.979962-0.983881 2944094.021687
0.983881-0.987801 2581591.763593
0.987801-0.991721 1953734.254538
0.991721-0.995641 792467.715584
0.995641-0.999561 899.509325
* 754476039.706173
So what is going on here?
Steve
(attachments)
pastedGraphic2.tiff (6.21 KB)
