[GRASSLIST:2505] alpha blending
Hello,
I was wondering if there is a trick or even a module which enables transparency on a vector poligon (with rasters I guess you can use a trick with the hue-saturation module). I saw Radim's qgis implementation of GRASS rasters and vectors, including alpha blending (http://mpa.itc.it/radim/qgis/) so I was wandering if something similar is/will be/might be implemented in GRASS
Thanks
Francesco Pirotti
CIRGEO -University of Padua
phone. 049 - 8272522
fax. 049-8272686
cel. 328-2126861
francesco.pirotti@unipd.it
Nothing like that currently exists in the display architecture, and
isn't likely to be added any time soon.
The simplest solution is to convert everything to rasters, and either:
a) export the rasters to a standard image format (e.g. PPM), and use a
paint program (or image processing utilities such as pbmplus/netpbm)
to blend them,
b) use d.his or r.his, or
c) use r.mapcalc.
On Sat, Feb 07, 2004 at 12:10:53PM +0100, francesco.pirotti wrote:
Hello,
Hi Francesco,
once there have been efforts to implement alpha blending into XDriver
(together with some RGB updates, maps as selectable layers etc):
Check
src.todo/display_driver/
Maybe the code is useful to re-implement these changes into
the current XDRIVER. It was never finished unfortunately.
Hi Francesco,
Check
I don't see anything in that which relates to alpha blending.
