Is there any way of circumventing the file size limit in r.bilinear? I am running it on a 30m DEM for a moderate-sized watershed, and keep running into the file limit size error.
Chris
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
Only by using a platform whose "long" is 64 bits.
On a platform with a 32-bit "long" type, handling files larger than
2Gb involves re-writing the code to use the "large file" extensions.
In this case, "the code" means libgis and anything which uses it, i.e.
the whole of GRASS, and we don't have anywhere near enough manpower
to accomplish that.
