Hello, strange error this time.
I start grass 5.7 and everything is fine. If I type d.m to start a new
display manager from the terminal it gives me the following error
message:
Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
Application initialization failed: this isn't a Tk applicationcouldn't
connect to display ":0.0"
Error in startup script: this isn't a Tk applicationcouldn't connect to
display ":0.0"
while executing
"load /usr/lib/tk8.4/../libtk8.4.so Tk"
("package ifneeded" script)
invoked from within
"package require Tk 8.0"
invoked from within
"package require -exact BWidget 1.2.1"
(file "/usr/local/grass5.7src/dist.i686-pc-linux-gnu/etc/dm/d.m.tcl"
line 2)
If I try to start a new monitor "d.mon start=x1" from the terminal it
gives me a similar error:
ERROR: Graph_Set: can't open Display :0.0
No socket to connect to for monitor <x1>.
Problem selecting x1. Will try once more
All this also happens in grass5.3 (with d.mon and d.dm), and in both
cases ONLY when the command is given from the terminal. If I start a
monitor or the display manager from the tcltk interface in 5.3 it is
fine.
Any ideas? (I am running tk8.4 on Linux Mandrake 10)
Thanks guys,
Francesco Pirotti
CIRGEO - University of Padua
message:
This is an X authentication error. This indicates that
$HOME/.Xauthority (or the file referenced by $XAUTHORITY, if that is
set) is, in some sense, invalid.
One common reason for this is if $HOME isn't set correctly. Try
running "xauth list" to view the list of authentication credentials
which are available to Xlib.
Thanks Glynn,
You are certainly right, about xauth.
I did not yet find a solution: I found though that if I try to call a
tcltk object directly from a terminal I get the
__________________-
____________________--
error BUT if I run the GRASS shell as root I get the diplay manager
without problems ...
I am not an expert on X so I doubt I will be able to solve this
mystery...
If anybody has any ideas, I'll be glad to try them out.
Francesco Pirotti
> message:
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.571 / Virus Database: 361 - Release Date: 26/01/2004
__________________-
In that situation, I would expect you to get the same result for
running any X program from the terminal.
Check the ownership and permissions on the ~/.Xauthority file; it
should be owned by you.
An elegant fix to the problem...
I reinstalled a 9.1 mandrake version instead of the beta 10 version...
Thanks!
Francesco
> __________________-
Version: 6.0.583 / Virus Database: 369 - Release Date: 10/02/2004
