[GRASSLIST:2602] compilation with BLAS under OSX
During the configuration process, when --with-blas is specified, the configure looks for -lblas. Under OSX, using Apple's developer tools, the BLAS library is specified as cblas, therefore the configuration fails. Changing -lblas to -lcblas in the configuration file fixes this failure. Someone might want to alter the configuration file in CVS to look for either.
Chris
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
On Fri, Feb 13, 2004 at 02:06:22PM -0500, Christopher Fonnesbeck wrote:
look for either.
Note, that so far BLAS and LAPACK are unused (AFAIK).
The support is intented to future expansion, we all hope for
'gmath' library being extended with a nice statistical library.
Volunteers welcome to move existing code spreaded all over
GRASS into a single library.
[oops meant to send to list as well]
Chris,
That's strange, because there is no libcblas in Mac OS X, so -lcblas should not work (doesn't for me - MOSX 10.3.2 + current Dev Tools, never did as far back as MOSX 10.1).
Blas IS included in the vecLib framework in OS X, tho (that's probably where you found the cblas reference, I think that's how I found the vecLib thing). The way I've always fixed this is to patch configure by changing all occurrences of '-lblas' to '-framework vecLib'. At the same time you can change all '-llapack' to '-framework vecLib' to get lapack - it's also in the vecLib framework.
On Feb 13, 2004, at 1:06 PM, Christopher Fonnesbeck wrote:
Chris
William Kyngesburye <kyngchaos@charter.net>
http://webpages.charter.net/kyngchaos/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
