[GRASSLIST:2620] v.net.path
Hello dear list,
I have some problems in 5.7, I wish you help me…
  1. Sometimes that I use of d.what.vect, it shows me:
    Buttons
    Left: what’s here
    Middle: toggle flash color
    Right: quit
    But when I click left key of the mouse on the map
    nothing happens and if I do it again it shows:
    Broken pipe
    and quit from d.what.vect
  2. When I am successful on use of d.what.vect, I have
    these values on my street map:
    Type: Point
    field: 1
    category: 6
Type: Point
field: 1
category: 160
Now I want to find the best path between two
points
so I use:
v.net.path input=Teh_Vect output=t2 type=line
afield=1 nfield=1
It shows:
Vector ‘t2’ already exists and will be
overwritten.
Building graph:
Registering arcs … 100%
Flattening the graph … done.
Graph was built.
Now I write :
6 160 (Is it correct?)
But nothing happens.
I changed my command like this:
v.net.path input=Teh_Vect output=t4 afield=1 nfield=2
Now it shows:
Building graph:
Graph was built.
WARNING: 61 points without category.
6 160
WARNING: No point with category 6
WARNING: No point with category 160
Would you please tell me my wrong and explain me more
about v.net.path?
Thanks a lot
Maliheh
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online
What 'nothing happens' does mean? Empty vector? You should close
stdin by Ctrl-D, and it shoud do something.
BTW, I would recommend to use different field for points, so that you can later link
arcs (lines) and nodes (points) to different tables with different structures.
Radim
On Sunday 15 February 2004 09:47, you wrote:
Hello dear list,
I have some problems in 5.7, I wish you help me...
     Buttons
     Left: what's here
     Right: quit
     Broken pipe
     Type: Point
     field: 1
     category: 6
     Type: Point
     field: 1
     category: 160
points
    so I use:
afield=1 nfield=1
    It shows:
      Vector 't2' already exists and will be
overwritten.
      Building graph:
      Registering arcs ... 100%
      Flattening the graph ... done.
      Graph was built.
    Now I write :
Now it shows:
Building graph:
Graph was built.
6 160
about v.net.path?
Thanks a lot
Maliheh
Do you Yahoo!?
