Dear GRASS user,
I'm trying to compile GRASS5.3 (grass53src_cvs_snaps..> 14-feb-2004 05:49)
following the instructions of /grass5/source/README.html.
The commands
gunzip grass53src........tar.gz
tar -xvf grass53src......tar
worked well, but the new directory mentioned in the instructions:
A) If you have "root" access to your machine:
Jump into the new directory "grass5.0.X" (change X to the current
release number):
cd grass5.0.X
is not created. The questions are:
does the snapshot version require a different installing procedure?
may be the directory is created with a very different name (CVS?) ?
have I to manually create the directory ?
Many thanks in advance
Aldo Clerici
Dip. Sc. della Terra Univ. Parma
