[GRASSLIST:2680] extracting vector attributes
I am trying to determine the area of each polygon in a layer, and store this statistic as a column in the attribute table (my vector attributes are stored in MySQL). There appears to be no vector function in the reference manual that provide this function, but I'm sure there must be something that does this. Please point me in the right direction.
C.
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
v.to.db option=area
More precisely/generally, it does not update each row in the table by area size
of each polygon, but by the sum of area sizes of all polygons with the same category.
Radim
v.to.db should do the job:
option=string
    Uploaded value: cat - insert new row for each category if doesn't exist yet area - area size
length - line length
count - number of features for each category
coor - point coordinates
query - result of a database query for all records of the geometry (or geometries) from table specified by 'qfield' option
    Options: cat,area,length,count,coor,query
http://grass.itc.it/grass51/manuals/html57_user/v.to.db.html
v.to.db option=area
OK, it sounds like I will have to program something. I need the area of each polygon as an attribute field, since I am trying to classify stream segments by the size of the sub-basin that drains into it. The easiest thing, I suppose would be to take both coverages over to ArcView, since this is a trivial operation there (but that would be cheating, I guess ;-] )
C.
>> store
>> attributes
>> be
> v.to.db option=area
> area size
> same category.
Why? What is the problem? Why you cannot use v.to.db?
If you don't have unique category for each polygon you can add it
by v.category.
Radim
store
attributes
be
v.to.db option=area
area size
same category.
by v.category.
Well, my vector layer of polygons comes from a raster layer, via r.to.vect, which creates a mysql table with cat and value columns, and an empty label column. Then, running:
v.to.db map=basins type=boundary option=area units=h
gives me a dbmi protocol error. Is this because the table already exists? I am assuming this means I have to write some C code to get the areas, create a database column, and load the values.
C.
The column must exist in the table (double precision) and must be specified (col1).
Radim
