[GRASSLIST:2698] Problem importing arc info file
I'm trying to import a arc info file with r.in.gdal, because it is not
supported by r.in.arc (it has not the header section).
The command seems work well but when I display the raster only a little part
is right and the rest of the cells of the raster have the value of the
category set to 0.
Can someone help me?
Thank you
Leonardo
You can easily add the appropriate six line header from the file characteristics
Leonardo Lami wrote:
I'm trying to import a arc info file with r.in.gdal, because it is not supported by r.in.arc (it has not the header section).
The command seems work well but when I display the raster only a little part is right and the rest of the cells of the raster have the value of the category set to 0.
Thank you
Leonardo
Sorry but I have never worked with arc/info files and so i have again
problems.
I have seven files for my dtm layer:
dblbnd.adf
hdr.adf
log
prj.adf
sta.adf
w001001.adf
w001001x.adf
I added:
yllcorner:4675800
xllcorner:1550000
nrows:2492
ncols:2272
cellsize:100
at the bottom of the w001001.adf file but when i run r.in.arc the output
message say:
r.in.arc: ** errors detected in header section **
  illegal line in header
  "yllcorner:4675800"
  "yllcorner" field missing from header
  "xllcorner" field missing from header
  "nrows" field missing from header
  "ncols" field missing from header
  "cellsize" field missing from header
  "nodata_value" field missing from header
Can't proceed
May be I mismatch the file where I add the header or its format.
Can you help me
Thank you very much
Leonardo Lami
characteristics
> Thank you
> Leonardo
