Hello,
I am trying to compile grass57 on mandrake 9.2, and it seems work, but when I
tried to run the program (text mode) this error happens:
/usr/local/grass57/etc/Init.sh: line 1: g.gisenv: command not found
GRASS 5.7.-cvs:/opt > g.list rast
bash: g.list: command not found
and no command works.
if I un the programm as text: grass -text the problem is greater, and I cannot
begin grass:
/usr/local/grass57/etc/Init.sh: line 497: GISDBASE: parameter null or not set
[daniel@grass opt]$
But, I have succesfully compiled grass50 first and all commands work, in a text
and in a graphical mode.
Any ideas?
regards and thanks a lot.
Mensaje enviado mediante una herramienta Webmail integrada en *El Rincon*:
------------->>>>>>>> https://rincon.uam.es <<<<<<<<--------------
On Tue, Feb 24, 2004 at 12:36:40PM +0100, daniel.pastor@uam.es wrote:
Hello,
Are you sure that the compilation went well? I use it on Mandrake 9.1,
which should not be so different from 9.2.
begin grass:
[daniel@grass opt]$
Any ideas?
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
