starting to try the new vector management in grass57, I'm looking for the
module called v.in.dwg
in grass57 tutorial, maibe this function is performed with a new one with a
different name?
thanks, Michele.
different name?
thanks, Michele.
On Tuesday 24 February 2004 15:24, Michele wrote:
different name?
You have to download OpenDWG library and compile it yourself.
Radim
On Tue, Feb 24, 2004 at 03:24:29PM +0100, Michele wrote:
different name?thanks, Michele.
v.in.dwg needs the openDWG libs: you have to compile this command
locally after getting these libs. We are not allowed to distribute
v.in.dwg binaries due to the openDWG license.
I'll add a hint in the tutorial.
