Hello,
I’m installed GRASS5.7 from the source of grass5.3_exp_17_01_2004
in my platform redhat8.0 but when i use the command ogr, d.m, or d.vect i get the following error. can you help to resolv all this error:
GRASS 5.7.-cvs>d.m
>GRASS 5.7.-cvs:~ > Error in startup script: child killed: bus error
while executing
>“exec ps.map -p”
(procedure “DmPrint::init” line 14)
invoked from within
>“DmPrint::init”
(procedure “main” line 30)
invoked from within
>“main $argc $argv”
(file “/usr/local/grass57/etc/dm/d.m.tcl” line 785)
>GRASS 5.7.-cvs:~ > ogr2ogr
ogr2ogr: relocation error: ogr2ogr: undefined symbol: _ZTV13OGRLinearRing
>GRASS 5.7.-cvs:~ > d.vect --help
>bus error
Thanks
Yahoo! Mail : votre e-mail personnel et gratuit qui vous suit partout !
Créez votre Yahoo! Mail
Dialoguez en direct avec vos amis grâce à Yahoo! Messenger !
On Fri, Feb 27, 2004 at 10:48:30AM +0100, hamdi ines wrote:
Hello,
I'm installed GRASS5.7 from the source of grass5.3_exp_17_01_2004
>GRASS 5.7.-cvs>d.m
while executing
>"exec ps.map -p"
(procedure "DmPrint::init" line 14)
invoked from within
>"DmPrint::init"
(procedure "main" line 30)
invoked from within
>"main $argc $argv"
(file "/usr/local/grass57/etc/dm/d.m.tcl" line 785)
You may need a fresh OGR/GDAL. Try the 1.2.0 from
http://www.remotesensing.org/gdal/
hello,
Markus i don’t understand your answer because it concerns only the ogr2ogr error, but don’t answer me how resolv the problem with d.m, d.vect grass command error, and what signify bus error.
Hello,
GRASS 5.7.-cvs>d.m
while executing
“exec ps.map -p”
invoked from within
“DmPrint::init”
invoked from within
“main $argc $argv”
On Mon, 1 Mar 2004, [iso-8859-1] hamdi ines wrote:
hello,
Markus i don't understand your answer because it concerns only the ogr2ogr error, but don't answer me how resolv the problem with d.m, d.vect grass command error, and what signify bus error.
The idea is that many GRASS 5.7 modules depend on GDAL/OGR. The way the
build system is set up now many modules that don't even use it are linked
against the GDAL shared library as a consequence of it sometimes being
used by the internal GRASS gproj library (I suspect this is the case with
ps.map, which is run by d.m).
In addition to updating to a new version I would also check that your current
GDAL/OGR is installed properly, especially that the libraries are in a location
specified by your LD_LIBRARY_PATH environment variable or in
/etc/ld.so.conf (run ldconfig after changing that).
But there is a good chance updating and re-installing your GDAL/OGR will
fix the problem and that is why Markus suggested doing that before you are
sure it's a GRASS problem that someone will take the time to look into
further.
Paul
> hello,
It is important, when upgrading the GDAL/OGR lib to 1.2.0, to remove
properly the old files. In older versions of GDAL/OGR the library was
split into several files (gdal.a, ogr.a, ...). Clean off these files
first, the compile/install the new version (libgdal.so....), then
reconfigure/recompile GRASS (as you are working with source code) to be sure
that it picks up the new library.
I have upgraded GDAL/OGR on grass.itc.it to the latest version, the
precompiled Linux binaries are linked to that now:
http://grass.itc.it/grass51/binary/linux/
further.
Paul
