[GRASSLIST:281] r.out.gdal problem
Hello,
I somehow don't completely understand the usage of r.out.gdal. I prepared a graphic (which is an imported tiff) with r.composite. I can export it with r.out.tiff without any problems. But how can I use r.out.gdal to export it as JPEG (or GTiff with TILED=YES). I always fail to specify the correct option for the required "type". I already tried every possibility which is listed (Byte, Int16,...), but without success. What "type" do I have to use?
Thanks
Wolfgang
