[GRASSLIST:287] Source packages
Is there a convention for naming GRASS source packages? I ask because I've been playing with building RPMS and DarwinPorts packages which assume the source package name and the extracted directory name will be the same. (e.g. they expect grass-5.0.2_src.tar.gz to extract to 'grass-5.0.2_src/' but it extracts to 'grass5.0.2/')
That's an oversimplification, there are work-arounds but there seems to be a convention of APPNAME-VERION for the source directory.
Has this issue ever come up? Are the maintainers aware of it? Do you think anyone cares?
It's certainly nothing critical, I'm just curious.
  Sean
Mea culpa - the *GRASS* naming "convention" was a sort of evolving
over the years.
think anyone cares?
Not yet :slight_smile: But I see no problem to update the scripts to follow
a well known naming convention. Let me know what's common and
I'll update the cronjobs.
No problem. If things can be made better, we should improve them.
Markus Neteler
Note that SRPMS for some GRASS versions are created by the FreeGIS project.
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
over the years.
think anyone cares?
%{name}-%version}.tar.gz containing %{name}-%{version}/ is customary,
for about 90% of the packages I have made, then some have
%{name}-%{version}_src.tar.gz containing %{name}-%version}/ .
Since source is typically the standard way of distribution, and there is
no such thing as a generic binary, IMHO, the _src suffix to the version
is useless.
The big thing though is that the directory name should be
%{name}-%{version}, to avoid having all RPM packagers having to add "-n
%{name}%{version}" or "-n %{name}_%{version}" or similar to %setup.
Most important thing is to be consistent though ... otherwise we keep
having to make patches like this for no reason:
http://cvs.mandrakesoft.com/cgi-bin/cvsweb.cgi/contrib-SPECS/grass/grass.spec.diff?r1=1.7&r2=1.8
- -%setup -q
+%setup -q -n %{name}%{version}
It's been mentioned before (so 5.0.0 was right), so chances are that the
actual naming of the directory in a release is not done by a script, but
should be ...
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE+4KodrJK6UGDSBKcRAiJmAJ9LkQMnVuYbNS7SIxe39Ns1cCzd6QCgsfri
qvPlFLeoJ2DP0LKRjuVhDZQ=
=O46V
-----END PGP SIGNATURE-----
Please click on http://www.cae.co.za/disclaimer.htm to read our
e-mail disclaimer or send an e-mail to info@cae.co.za for a copy.
