Dear all,
I follow your help and it wors very well but if the buffer overlap?
I see that if I convert to rast a vector with two circles overlapped the
circles take the same value (the value of one of these).
I'd like to have the a rast with the areas not overlapped with the rigth value
of the vector circles and the area overlapped with a value = at the sum of
the value of the two circles.
Is posiible that or something near at that?
Thank you very much.
Leonardo
Ciao,
scusa, ok, now I got your problem. Yes, v.buffer does NOT transfer the
attributes because of potential buffer overlap (which cannot be resolved
automatically).Solution, if circles do not overlap:
#Example for Spearfish data (use v.in.sites to convert old sites data):
v.buffer input=archsites output=circles type=point buffer=200
# change original points to centroids:
v.type in=archsites out=archcentroids type=point,centroid# patch circles and centroids:
v.patch in=archcentroids,circles out=circles_db# attach attributes, either use
# db.copy ...
# or link to the original table:
v.db.connect map=circles_db table=archsites field=1 key=cat driver=dbf
database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf'd.vect circles_db
d.what.vect circles_dbI have added this example to the documentation.
On Fri, Feb 20, 2004 at 03:46:20PM +0100, Leonardo Lami wrote:
> Dear Markus,
> I am Leonardo Lami, a collaborator of Paolo Cavallini (Faunalia), and I'm
> working on a a environmental model with him.
> I'm working with the command v.buffer but I have a problem:
> I'd like to create circle buffer vectors (type area) of some points where
> the category of the single circle centroid results to have the value of
> the category of the relative point.
> It's possibile to do that in automatic?
> If not, would it be hard for you make this optional for the command
> v.buffer?
> Thank you a lot
> Leonardo
