[GRASSLIST:2890] problems displying sites
hello!
I have a site file within grass5 with 1335 sites (all of them recognized by s.info) but d.sites only displays some of them.
s.to.vect convert all sites and d.vect displays correctly all sites (now vectors).
Can anybody explain me what should I do to resolve this problem?
Thanks in advance
Juan Pablo
_________________________________________________________________
¿Estás pensando en cambiar de coche? Todas los modelos de serie y extras en MSN Motor. http://motor.msn.es/researchcentre/
(now vectors).
Are you sure the sites file is valid?
e.g.
x|y|#1 %1.234
Could you reduce the sites file to a couple of lines of working sites
and a couple of lines of non-working ones? I'm pretty sure it is
skipping over them because the format isn't quite correct/consistent.
Hamish
The only time I've come across something like this is when I was using latlong location and looking at a region that crossed 180E. Using d.sites only displayed those sites on one side of the 180E meridian. I've just dragged the same site file into Grass57 using v.in.sites and that displays sites on both sides of the 180E meridian.
I guess that is a pretty specific explanation - only useful if you are also looking at a latlong location spanning the 180E meridian!
David
On 10 Mar 2004, at 11:19, juan pablo perez wrote:
hello!
Thanks in advance
Juan Pablo
