[GRASSLIST:2906] proj4 and grass57
I have a problem with proj4 library, using debian3.0 and compiling grass57:
checking for location of External PROJ.4 includes...
checking for proj_api.h... yes
checking External PROJ.4 version... 445
configure: error: *** PROJ.4.4.6 or later is required.
I was trying to exclude proj4 use using the "--without-proj4 or --without-proj"
option but it doesn't work.
Anyone can suggest some fix for this?
thanks, Michele.
grass57:
--without-proj" option but it doesn't work.
You can install the Debian/testing version of PROJ (4.4.7) as follows:
add the following to /etc/apt/apt.conf
APT
        Default-Release "stable";
then, edit /etc/apt/sources.list and make a copy of the line with your
mirror after the existing one, but change 'stable' (or woody) to 'testing'
apt-get update
apt-get -t testing install proj
Downside of that is it might want to upgrade libc6 while it's at it.
To get around that, add a "deb-src ... testing" line to sources.list,
apt-get update
apt-get -t testing --compile source proj
dpkg -i your_new_proj_package.deb
I think... it's been a while since I've had to do this.
good luck,
Hamish
