[GRASSLIST:291] (no subject)
There are some ways how to run GRASS commands from a script
(for example, "Grass interface to other languages" thread was concerned with
this problem). My question is - is it possible to create new location and/or
mapset from within a script? Or is it necessary to do it interactively?
Thanks in advance,
Peter
There isn't any official non-interactive mechanism for creating
locations or mapsets.
However, it's simple enough to create and configure the directories
manually. A new location needs a PERMANENT mapset containing MYNAME,
DEFAULT_WIND and WIND (the last two would typically be identical),
whilst a new mapset just needs a WIND file.
