Can I have two versions of GRASS (5.0 and 5.3) installed at the same time, and if not, will GRASS5.3 simply overwrite 5.0 or do I need to uninstall somehow. I am planning on trying the 5.3 binary provided by R. Greenwood since I have no idea how to compile the sources.
Thanks.
Martin
It should not be a problem. By default, it will install into /usr/local/grass53. You can start it with "grass53". "grass5" will still launch your current version of grass.
Have 5.3 up and running, and I have even figured out the GUI (nice), but is there some way to also use the command-line from within the GUI. For example I cannot set the -z flag in r.patch?
Martin
At 08:08 AM 3/12/2004 -0700, you wrote:
Martin du Saire wrote:
Thanks.
Martin
Martin
If you start the GUI with "tcltkgrass&" or "tcltkgrass &" then you should be able to enter grass commands. The key is to put the "&" at the end of tcltkgrass command. This causes tcltkgrass to be launched but tells the shell not to wait for it to finish.
