[GRASSLIST:2956] vector point icon + nviz vector 5.7 area paint
Hello,
Two curiosities:
I peeked into the folder symbol/basic and symbol/demo which contains the script to represent the choices of icons to represent a vector point or centroid. I added the X and the two symbols in the demo folder (a tree and a mushroom icon) in d.m and everything worked fine.
Can I have some info on the syntax for making my own symbols? I saw that one can draw a line, or a polygon or an arc. Is there anything else? Can these scripts support loops?
All these questions because I would like to make a meshed symbol, like a checker board where the white squares are transparent so that my symbol has transparency. The problem is that if the size gets bigger the mesh grows larger, and thins out the elements instead of keeping the mesh resolution and simply increasing the number of elements.
NVIZ: I did not manage to draw 5.7 vector polygons and or centroids/points but only lines. Is it my problem or is it still under construction??
Francesco Pirotti
CIRGEO
On Tuesday 16 March 2004 21:10, francesco.pirotti wrote:
Hello,
Two curiosities:
/grass51/lib/symbol/README
No loops.
Radim
