[GRASSLIST:2986] Import map from PostGIS
I'd like to import a vector from postgis but i have a problem.
I readed the session "Generating vector geometry from PostGIS table" in the
grass 5.7 tutorial but the example is valid only for a vector type point.
If I use the command:
  echo "select x(geo),y(geo),num from localizzazione" | db.select -c |
v.in.ascii out=mitris
the command doesn't work because the the format of the column "geo" is
different in a linear vector.
How can I do?
I see that when I delete the map, also the PostGIS table would be deleted but
it is not useful.
Is possibile insert an option that can save the table in PostGIS when you
delete a map linked to the table or something else to resolve it?
Thanks
Leonardo Lami
On Friday 19 March 2004 15:00, Leonardo Lami wrote:
How can I do?
but it is not useful.
Why not v.in.ogr?
Radim
