Hello All,
As I have some huge vector maps to process I thought giving GRASS57 a go. I
use GRASS53(2004/01) on a ix86/Suse8.2 box. For info, my gcc compiler has
version 3.3 20030226 (prerelease) (SuSE Linux). I downloaded the latest
sources (2004/03/13), the configuration goes smoothly.
I have a couple of warning during the make
alloc.c: In function `G_malloc':
alloc.c:23: warning: passing arg 1 of `malloc' as unsigned due to prototype
asprintf.c: In function `G_asprintf':
asprintf.c:42: warning: passing arg 1 of `calloc' as unsigned due to prototype
cats.c: In function `G_sort_cats':
cats.c:1189: warning: passing arg 1 of `G_malloc' as signed due to prototype
color_hist.c: In function `G_make_histogram_log_colors':
color_hist.c:117: warning: passing arg 1 of `log' as floating rather than
integer due to prototype
icon.c: In function `G_plot_icon':
icon.c:24: warning: `np' might be used uninitialized in this function
mach_name.c:18: warning: `attname' defined but not used
I liberally edited the logfile, you have the idea.
On a sadder note, I die there :
make[2]: *** No rule to make target `OBJ.i686-pc-linux-gnu/spawn.o', needed by
`/home/storage/pg56/Transitzone/sources/grass57_exp_2004_03_13/dist.i686-pc-linux-gnu/lib/libgrass_gis.so'.
Stop.
make[2]: Leaving directory
`/home2/Transitzone/sources/grass57_exp_2004_03_13/lib/gis'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory
`/home2/Transitzone/sources/grass57_exp_2004_03_13/lib'
make: *** [default] Error 1
Any idea of fix ?
Thanks a lot...
Pierre
Pierre GERARD-MARCHANT
Soil & Water laboratory
Biological & Environmental Engineering
Cornell University
ITHACA, NY 14850
Tel : (607) 255.2463
"It's more fun to compute" - Kraftwerk
Soil & Water Laboratory
Dept. of Biological & Environmental Engineering
Cornell University
ITHACA, NY 14853
Tel: (607)255.2463
