[GRASSLIST:30] Grass and Xwin32
Does anyone has any experience in running Grass on a PC through Xwin32 or exceed?
I installed Grass on linux and try to run it through Xwin32 on my PC. The problem is that I cannot get the graphical window by tcltkgrass& command. It appears and get blocked.
Christian
I used the StarNet X-server evaluation version and the detailed instructions on the Grass site under Win 2000 SP3 and everything worked first try. I also got the full-screen XFree86 server working with the appropriate instructions on the same Grass information page. I burned a CD with the necessary files and the detailed instructions I followed to act as a guide for future attempts.
Christian
