[GRASSLIST:3075] Re:overlay site attributes on areas
Dear David,
If you want to display polygon and points together simply run d.dm& (in grass50/53) at the command line and use the graphical interface do do that, yuo can display any type of map (raster, vector and site).
If you want to generate a single map, with:
s.to.vect (make a vector map from site)
v.patch (pach 2 or more vector map in one single map).
Michele.
Wasn't there a command to do point in polygon (vector) overlays? I thought
I remembered doing this, but I can't remember how.
David Mahoney
Llarix Solutions
Box 967, 1215 9th Ave.
Valemount, BC V0E 2Z0
250-566-4163x208 days
mahoneyd@unbc.ca
