[GRASSLIST:3096] bus error in grass57
Hello,
i have installed grass 57( grass57src_cvs_snapshot_exp_2004_01_17.tar) in my linux platform(redhat8.0) with the head version of grass53 (GRASS-5.3-cvs-head-i18n.22jan2004.tar), and gdal040308, xerces1.6.0…but when i run grass i had an error message and i have a problem with the all vector command like d.vect, v.in.ogr like described below but the ogr command run correctly like ogr2ogr…
GRASS 5.7.-cvs:~ > Error in startup script: child killed: bus error while executing
“exec ps.map -p”
(procedure “DmPrint::init” line 14)invoked from within
“DmPrint::init”
(procedure “main” line 30) invoked from within “main $argc $argv”
(file “/usr/local/grass57/etc/dm/d.m.tcl” line 785)
GRASS 5.7.-cvs:~ > d.vect
Erreur du bus
GRASS 5.7.-cvs:~ > v.in.ogr
Erreur du bus
GRASS 5.7.-cvs:~ > v.out.ogr
Erreur du bus
GRASS 5.7.-cvs:~ > v.extract
Erreur du bus
my question is how resolv this problem with vector command and the d.m command.
THANKS.
INES
Yahoo! Mail : votre e-mail personnel et gratuit qui vous suit partout !
Créez votre Yahoo! Mail
Dialoguez en direct avec vos amis grâce à Yahoo! Messenger !
