[GRASSLIST:314] Printing site descriptions
Hi, I've managed to print each site's description with ps.map, but I'm
having the following problems (I enclose a small jpg which shows them
well):
1) The description is framed by a border with large width. Is it
   possible to get rid of that border?
2) The description has a white background. Is it possible to not have
   background? (Or to have transparent background?)
3) I can't print descriptions with Greek (iso-8859-7) characters. I
   suspect I have to specify the correct font in the ps.map input
   file, but I'm confused: do I have to specify a ghostscript font name
   like those found in /usr/share/gs/X.XX/Fontmap.GS?
4) Is there any way to specify the position of the description, so
   that it does not interfere with other sites or map elements?
Thanks!
Here's the relevant part from my ps.map input file:
sites monuments
  color black
  eps monuments$.eps
  size 1
  desc y
  font Roman
  end
well):
No.
No.
Yes. All PostScript implementations have the Greek alphabet in the
"Symbol" font, but that uses PostScript's non-standard SymbolEncoding,
so you would have to convert the text somehow.
You could probably configure Ghostscript to use an ISO-8859-7 font,
but printing to a PostScript printer (or even generating PostScript
files which others can read) would be more problematic.
No.
Glynn Clements wrote:
  [ When you print site descriptions with ps.map, you can't get rid of
  the border and background color, and you can't specify placement. ]
OK, so what's the workaround? You use the ps.map "text" command instead
of printing site descriptions? How about when you have a map with many
names, such as a map with, say, 500 towns and villages? You create a
huge ps.map input file with 500 "text" commands? Is this a missing
feature of GRASS?
feature of GRASS?
Yes, it's a missing feature.
GRASS is primarily an analysis package; its cartographic abilities are
fairly basic.
You may wish to look into GMT:
  http://gmt.soest.hawaii.edu/
If you want to make a good looking map, either export files in Arcview format and work in Arcview, or export the eps and work in a drawing programm like Adobe Illustrator.
Konstantinos Theofilis
feature of GRASS?
fairly basic.
Export to EPS and then with some drawing program (Sketch in my case; you
need also pstoedit to be installed) edit the drawings to get desired
results.
Matej
Matej Cepl,
GPG Finger: 89EF 4BC6 288A BF43 1BAB 25C3 E09F EF25 D964 84AC
138 Highland Ave. #10, Somerville, Ma 02143, (617) 623-1488
