[GRASSLIST:3146] a problem in grass57
hello
when I used firstly grass57. I encountered suh a problem in nviz:
"couldn't execute nviz2.2_script"
what can I do ?
regards
Ahmet Temiz
TURKEY
______________________________________
Inflex - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
On Tue, Apr 13, 2004 at 03:08:18PM +0300, temiz wrote:
hello
what can I do ?
At time you cannot start nviz in 5.7 with GUI, use it
from command line instead:
nviz -q
or
nviz elevation.dem ...
I would appreciate a hint why the GUI startup doesn't
work. For some reason the $GISBASE/etc/nviz2.2/scripts/nviz2.2_script
is not found. Is there a way to simplify the startup script?
Regards
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
