I'm trying and failing to install GRASS 5.0.3 from source code. I suspect
I'm doing something truly dumb but I'm not sure what and I'd appreciate your
guidance.
As suggested in the installation instructions, I've created a directory (as
root) /opt/src/grass5sources and unpacked grass-5.0.3_src.tar.gz. Changing
to the directory grass5.0.3, I then run ./configure, which appears to run OK
(the only error is it cannot locate TIFF includes. This is an optional
module so I figured it should be OK).
Now comes the problem - when I run make I get the response:
bash: make#: command not found
which is understandable because there isn't a Makefile in my grass5.0.3
directory. There is a Makefile.in though, and when I run that (make -f
Makefile.in), it only runs briefly before failing thus:
@SRCDIR@/src/CMD/generic/is64bit.sh:
@SRCDIR@/src/CMD/generic/is64bit.sh: No such file or directory
What am I doing wrong? Any guidance gratefully received,
Robert Holmes
Robert Holmes wrote:
guidance.
Robert Holmes
Try
./configure --with-tiff=no
You do not have a Makefile because configure failed at the tiff option. If configure succeeds, it will list the various options and create a Makefile. Makefile.in is the initialization, or seed, file for configure and is not meant to be built.
Richard Greenwood
www.greenwoodmap.com
Richard - many thanks, that worked nicely - Robert
-----Original Message-----
From: Richard Greenwood [mailto:rich@greenwoodmap.com]
Sent: 13 April 2004 20:21
To: Robert Holmes
Cc: GRASSLIST@baylor.edu
Subject: [GRASSLIST:3153] Re: Cannot get the makefile to work
> Hi all,
> suspect I'm doing something truly dumb but I'm not sure
what and I'd
> appreciate your guidance.
> directory (as
appears to run OK
an optional
> grass5.0.3 directory. There is a Makefile.in though, and when I run
> that (make -f Makefile.in), it only runs briefly before
failing thus:
> Robert Holmes
Try
tiff option.
for configure
Richard Greenwood
